Looking for ‘29 Coupe Rear Wheel Well Patch Panels That Fit I’m looking for a pair of these - Patch panels that have the correct dimples on the leading edge of the panel, the dimple on the rear where the rear subrail attaches - in addition to the three embossed ribs. All I can find online now are flat panels with only the three ribs.
Is there a current course of these patch panels made with all the correct dimples ?? Many thanks - Jim |
Re: Looking for ‘29 Coupe Rear Wheel Well Patch Panels That Fit Quote:
Re: Looking for ‘29 Coupe Rear Wheel Well Patch Panels That Fit Conway…
Do you/can you mig and/or tig weld. Do you have access to a small sheet metal brake? Brent is correct no one now makes the correct contour panel. |
Jim |
Jim |
Re: Looking for ‘29 Coupe Rear Wheel Well Patch Panels That Fit I posted on your post last time.
If you will email me at [email protected] I can shed some great light on such a project. I do that regularly and just finished a rough out of it in a 68c |
Re: Looking for ‘29 Coupe Rear Wheel Well Patch Panels That Fit I've fabricated several size dimpling tools over the years. It takes time but sometimes a person has no choice. I have a thick steel table top and a piece of new rail road rail that I use with various different shaped forms to pound those shapes into the steel where needed. If I find old worn out chisels, I convert them into swaging tools to form shapes in steel. Wood forms can be made to make shapes for a limited number of blows before they are damaged. If a person uses steel forms they will last longer but I don't form a lot of sheet metal. A person can make dies to work in an old arbor press to form some beads. A bead roller is nice to have but a person can form stuff in other ways. It just takes longer. I can't afford a Pull Max so I use what I have. Angle irons and a vice can be used for braking an edge over on a panel. It's nice to have a brake but it can be done without one.
There are a lot of metal shaping videos on U-tube. Some are pretty good and some aren't but a lot of it is good information if you want to shape metal on your own. I learned a lot from Metal Meet and some of David Gardiner's work. |
