Water pump gasket When replacing the water pump, what’s the recommendation on using the gasket or a sealant or a combo? If sealer which product have you used? Thanks
Re: Water pump gasket Just use the gasket unless you have rough or damaged mating surfaces
Re: Water pump gasket Thanks for your reply.
