The Ford Barn
-   -   Flatty Generator (https://www.fordbarn.com/forum/showthread.php?t=310403)
tommyleea 02-25-2022 08:24 AM
Flatty Generator
Would it hurt the generator to run it with the wires disconnected? 53 Flathead.
Mart 02-25-2022 08:29 AM
Re: Flatty Generator
It shouldn't.
It's not advisable to run an alternator disconnected, though.
tommyleea 02-25-2022 08:58 AM
Originally Posted by Mart (Post 2108066)
It shouldn't.
Copy..Thanks..I might crank Flatty up today.
Kurt in NJ 02-25-2022 09:11 AM
A 2 brush generator should be ok, a 3 brush generator the output has to be grounded to prevent high voltage burnout--- a 3 brush energized the fields internally s shorting the output preventing any building voltage internally (can make over 40volts).
The 2 brush as long as no power goes to fields will be ok.
tommyleea 02-25-2022 10:10 AM
Is there an easy way to tell if I have a 2 or 3 brush generator?
It looks like the 3 brush has an extra part added to it? I think I have the 2 brush with a regulator...
terry 02-25-2022 10:26 AM
If you have a cut-out on top of the generator, Then it's a 3 brush. Terry
tommyleea 02-25-2022 10:39 AM
Copy..Thanks..I think I might start up the Flathead today!
tommyleea 02-28-2022 09:02 PM
Just an update. I got Flatty cranked up and broke in..All went well. Lesson learned, put a socket on the headbolt next to the thermostat housing, before you tighten the housing down...or your socket might not go over the bolt for retorque. Thanks to all..
