The Ford Barn
-   -   53 Ranchwagon (https://www.fordbarn.com/forum/showthread.php?t=310366)
tommyleea 02-24-2022 09:43 AM
53 Ranchwagon
Going through the wiring on the Ranchwagon. Under the dash there is one of the bakelite junction blocks. I believe it is for the turn signals. It has the mounting holes, but it is just hanging with the harness. Should it be bolted down somewhere under the dash, or is it correct as is? Thanks
51 MERC-CT 02-24-2022 10:22 AM
Re: 53 Ranchwagon
Have never seen any under dash junction blocks bolted to anything (just hang)
Under hood block bolted to inner fender.
tommyleea 02-24-2022 10:32 AM
Re: 53 Ranchwagon
Great .. Thanks for the response..
Robz51 02-25-2022 12:02 AM
Re: 53 Ranchwagon
I think it hangs from a hook under the dash. That's how my merc's was.
Rob
Sent from my SM-G960U using Tapatalk
