The Ford Barn
-   -   39 pickup bed mounting questions. (https://www.fordbarn.com/forum/showthread.php?t=309403)
Shampipple 01-29-2022 07:22 PM
I’m looking for photos or a diagram of where and how the bed mounting wood gets installed. As well as the metal cross members.
Any help is appreciated.
38bill 01-30-2022 09:51 PM
Re: 39 pickup bed mounting questions.
Are you going to replace the stock steel over wood bed or just do a wood bed?
Tinker 01-31-2022 12:29 AM
Please elaborate what pieces you have. Are we talking about a self build? Most bed pieces from companies have all the rivet holes predrilled.
There are two wood "risers" in the front and back of the bed. Where did you get the wood? The metal inner frame also rides on the rear frame wheel "humps".
Please expand what you are asking please.
Shampipple 02-04-2022 12:35 AM
I have the two wood bed risers, and three stamped steel cross members.
Original bed sides, bulkhead, and tailgate.
I’m putting a plywood floor in the bed, likely with a custom rubber mat for now.
I did receive some photos on another forum which I believe will help me a bit. But I’m always willing to learn from you guys.
Shampipple 02-04-2022 12:38 AM
https://uploads.tapatalk-cdn.com/202...682ec365e3.jpg
Ihttps://uploads.tapatalk-cdn.com/202...781c2efda0.jpg
I received these photos which help me a lot. I haven’t been able to figure out the large stamped section yet.
Tinker 02-05-2022 12:47 AM
What is the large stamped area you are talking about?
The front wood section also connects to the cab wood on the 37-early trucks. On the later there is a block under it. Also the front wood support sits on the cross member. Which the picture above doesn't have. Leaving the bed tilled forward a few inches as it sets now in the picture.
Shampipple 02-05-2022 12:55 AM
https://uploads.tapatalk-cdn.com/202...db7b888109.jpg
This is the piece I’m asking about.
Do you have any pictures or part numbers for the small block you’re speaking of?
Tinker 02-05-2022 01:05 AM
6 Attachment(s)
As you can see I don't have the block under the front wood yet. This is prep pictures. All was removed again.
Tinker 02-05-2022 01:06 AM
That's for the rear of the truck. Below the tailgate. It rivets to the frame with 2 rivets.
I can measure the block you need. It's just a block you can make from decent hardwood.
Tinker 02-05-2022 01:12 AM
1 Attachment(s)
And I misspoke the 38 and later were integrated to the cab. 37 and earlier are short of the bed. I used a block as mine isn't integrated.
Here is a sample of a 40-47...
Tinker 02-05-2022 01:23 AM
Show some pictures of what you are working on. Your project.
Shampipple 02-05-2022 07:07 AM
I will. I was at work responding to you. I won’t be at the shop where the truck is until Sunday.
I keep my vehicles at three different locations.
Shampipple 02-05-2022 07:15 AM
https://uploads.tapatalk-cdn.com/202...c1a0e957ed.jpg
https://uploads.tapatalk-cdn.com/202...d15f43f7e7.jpg
I just mounted the cab, and installed the cab wood a few days ago. I will lay out the supports and cross members tomorrow. I think the lack of the blocks was confusing me. I do see they sell some in the catalogs. But a measurement would help a bunch.
Tinker 02-11-2022 11:43 PM
I have not forgotten to get you some measurements. Wasn't around and it's -20 tonight. I'll crawl under this weekend and take pictures and measurements.
Shampipple 02-13-2022 08:51 PM
I think the blocks are 3 1/2”. Not a rush. It’s pretty cold here too.
Tinker 02-17-2022 01:50 AM
I tried crawling under tonight. But I was less then successful in getting a good measurement or picture in the cold and where it's located with the cross member. I admit I did not take much time in doing so.
I would suggest that you can use the measurement of the block based on the x-member relation to the bed wood cross piece. I used frame webbing also on the block to frame.
Shampipple 02-17-2022 04:53 AM
That’s exactly what I did. I laid a straight edge across the other crossmembers. I came up with 3 1/2”
38bill 02-17-2022 01:45 PM
2 Attachment(s)
Couple of photos.
Shampipple 02-18-2022 04:20 AM
Thanks! It looks like 3 1/2” is the ticket.
