The Ford Barn
-   -   Please Identify Stop Light Switch (https://www.fordbarn.com/forum/showthread.php?t=308410)
Dave1931Pickup 01-02-2022 06:39 PM
2 Attachment(s)
This switch was in a truck load of "A" parts that I bought. I'm sure it is not for a model A. Can someone identify what make of vehicle and what year it is for.
Thanks in advance, Dave
Bob Bidonde 01-03-2022 09:20 AM
Re: Please Identify Stop Light Switch
1 Attachment(s)
https://www.fordbarn.com/forum/attac...1&d=1641166677
That looks like a Model "A" stop light switch variant with different mounting provisions. I would remove those mount flanges and add one l;ike the Model "A" switch has.
Ray in La Mesa 01-03-2022 09:59 AM
Could be from the later V8 era.
GRutter 01-03-2022 10:25 PM
No brass bushings on the switch actuator would indicate it is a reproduction part.
I've not seen one with mounting flanges like that. Ford V8 thru about 38 had mounting tabs on one side. Maybe not a Ford part ?
Synchro909 01-04-2022 01:56 AM
All sorts of switches have been used over the years. Each time a switch failed, it was replaced with whatever was available at that location at that time.
We have to be creative with every brake light switch. Eg, the ones that bolt to the top of the gearbox are pretty useless here.
IMO, that switch has a future in a Model A.
rotorwrench 01-04-2022 10:16 AM
It's similar to those used in the mid 30s Fords. Ford used mechanical brakes longer than most so they used the mechanical switches longer as well but most can be found in reproduction form. There were other companies that used similar types. That particular one may be a universal fit type but I don't know for certain.
Bob C 01-04-2022 11:39 AM
1 Attachment(s)
Is this a name or part number?
rotorwrench 01-05-2022 11:39 AM
It reads "Pull On".
