The Ford Barn
-   -   Lower a arm spacer bolt size (https://www.fordbarn.com/forum/showthread.php?t=306554)
CJStefan 11-16-2021 04:07 PM
Anyone know what size bolts replace the rivets on a '49 Custom? I'm putting Aerostar springs on and taking the shock out, I broke one of the lower shock plate bolts. Heat and vice grips were no good. Now the arms coming off so I can drill the broken piece in the drill press instead of crouched under the car. Figure I may as well get rid of the rivets while I have easy access to do it. That way if I decide to do spacers or need to remove the coil again down the road I'm one step ahead
51 MERC-CT 11-16-2021 05:38 PM
Re: Lower a arm spacer bolt size
If you are talking about the (2) shock mount bolts, they are not rivets but 5/16" carriage bolts that are tacked or swaged into a square hole.
https://www.fordbarn.com/forum/pictu...ictureid=44218
https://www.fordbarn.com/forum/pictu...ictureid=44219
CJStefan 11-16-2021 06:14 PM
The rivets that hold the spring plate onto the lower control arm are what I'm talking about. When people put in those spacer blocks to lower the front end without cutting or changing the coils, what size bolts fit the holes where the rivets once were? The broken shock mount bolt is what started this whole thing
34PKUP 11-16-2021 07:30 PM
Are you unable to measure the holes? :confused:
TJ 11-16-2021 07:43 PM
Remove the rivets and measure the hole. That way you will only make one trip to the hardware store.
CJStefan 11-17-2021 02:16 PM
I was on my way to the hardware store store (30 min. each way) for something else before I pulled the a arm off the car. The plan was to pick the bolts up while I was there. Oh well
