The Ford Barn
-   -   Hanging brake pedal with original clutch pedal (https://www.fordbarn.com/forum/showthread.php?t=306216)
CJStefan 11-07-2021 08:40 PM
Anybody have a pic of how this looks? What I want to see is, does it look weird and out of place or is it really not noticable. I'm redoing all the brake hydraulics on my '49 Custom and I'm considering a firewall mount master. I want to keep the mechanical clutch setup though
fordor41 11-07-2021 10:36 PM
Re: Hanging brake pedal with original clutch pedal
I doubt anyone would notice, especially if the two pedals lined up and looked alike.
CJStefan 11-07-2021 10:56 PM
That's what I was thinking and I was set on doing it. Then a buddy of mine said something about it looking weird and I started thinking too much about it
tomcarman 11-07-2021 11:41 PM
I have to chuckle to myself as I have the same affliction. I over think things sometimes so much it paralyzes me. In my opinion unless you're going for factory correct concourse judging restoration simply hook everything up and drive it for enjoyment. If, in the end, you don't like it you can always change it.
19Fordy 11-08-2021 09:34 AM
It might feel different to your feet when you depress the pedals.
Charlie Stephens 11-08-2021 11:13 AM
I agree with you on this. One foot would have an arc going up and the other down. Must admit I have never tried it.
Charlie Stephens
A bones 11-08-2021 11:21 AM
After all these years, the feet can deal with it. As far as looks go, they become a badge of ingenuity.
tubman 11-08-2021 11:27 AM
When I was a kid, I had an acquaintance who did this. It worked OK, but looked, well, just wrong. He wasn't much of a mechanic, and it was the only way he could get a master cylinder to function. He didn't reinforce the firewall, and it flexed badly. I got involved and we reinforced the firewall which solved that problem. However, it looked terrible, and the whole thing ended up being a lot more work than doing it properly.
retep 11-08-2021 06:08 PM
I used to have that arrangement in my 34. It looked strange but also means you have your master cylinder on the fire wall.
CJStefan 11-09-2021 04:24 PM
I think I'm going to stick with it under the floor. It is more convenient to have it on the firewall but in reality once the new master and lines are in, I don't see needing to get to it for the next 5 or 6 years if not longer. I'm also going to put an access door in the floor pan to make it easier when I DO need to get to it.
TJ 11-09-2021 04:57 PM
I've seen some older cars with the MC on the firewall and does not look right. I've seen cars like that where the MC leaked and ruined the paint on the firewall. Put the MC where it was originally and you'll be happy.
Jack E/NJ 11-09-2021 05:31 PM
A Bones>>>As far as looks go, they become a badge of ingenuity.>>>
I changed mine that way. So, yes, I'd notice the ingenuity more than the weirdness right away 8^)
petehoovie 11-09-2021 06:25 PM
1 Attachment(s)
This?
https://www.fordbarn.com/forum/attac...2&d=1636500293
