The Ford Barn
-   -   Head gasket question (https://www.fordbarn.com/forum/showthread.php?t=305099)
Ken/Alabama 10-12-2021 04:22 PM
1 Attachment(s)
So which head gasket do I need to use on my stock 40 engine ?The one that match the block or the ones that match the head ?
flatjack9 10-12-2021 05:21 PM
Re: Head gasket question
I'd use the one with round holes.
Ken/Alabama 10-12-2021 05:27 PM
Thanks Jack. I was gonna reach out to you about this.
petehoovie 10-12-2021 05:57 PM
https://www.fordbarn.com/forum/attac...2&d=1634073742
Lawson Cox 10-12-2021 06:00 PM
I'd use the lower one myself. Larger holes allow more water flow. I know, more flow less flow debate has been going on for eons. That debate probably was started by the engine designers before designs went into production.
tubman 10-12-2021 07:39 PM
I don't know much about this, as I am strictly an "8BA Guy", but isn't there a rule saying you should use the gasket that matches the block?
Phil Gillespie 10-13-2021 12:55 AM
My understanding is:
The trapezoid centre holes were initial gaskets in use. Then to better control water flow circulating through the block the gaskets with the round centre holes were introduced.
All in the way to keep better overall block temperature.
I am using the ones with round centre holes in a 59a engine, recent rebuild.
Phil NZ
Tinker 10-13-2021 01:02 AM
Just a thought. The water travels through the block and heads at the openings made, the gasket, unless the holes in the gasket are smaller to restrict flow, won't do much. So it makes since. Distribute or constrict the water flow. Always put the small hole to the front of the block, like on a yblock. If not it'll have no effect. Moving water to the back of the block is a good thing. On a 59a that would force water to the rest of the block. I don't know for certain it's better. I'll leave that up to everyone else.
Not sure but I'd guess the heads don't have trapezoids. Or at least I have not seen it. Doesn't mean it doesn't exist obliviously. It would not surprise me that I know everything. That's a joke by the way.
Bored&Stroked 10-13-2021 05:37 AM
Either one will work fine . . . though I tend to only use the ones with round holes.
From everything I know (which is not much - LOL), Ford decided to restrict the amount of water flow that too easily headed up to the center water outlets on the 39-42 engines . . . supposedly forcing more water to the other areas of the block - especially the rear. One example is the 39 - 42 Merc blocks - where they changed the center trapezoid water hole for a smaller round one.
They continued this quest when they made the 49-53 blocks - where they had much bigger water outlet holes in the rear of the block than in the front. As some have noted, almost all engines run hotter in the rear cylinders that the front cylinders . . . location, location, location . . .
