The Ford Barn
-   -   Gas gauge quit (https://www.fordbarn.com/forum/showthread.php?t=304484)
Clem Clement 09-29-2021 12:53 PM
Gas gauge quit
My '40MERC's gas gauge quit recently. Reads nil. Reaching under the dash, I feel no loose wires. No problems in the last 4 years. I don't know if the sender is modern. Tank about 3/4full. Next step pickup the trunk mat and inspect the gauge top?
TIA
hotrodart 09-29-2021 02:14 PM
Re: Gas gauge quit
CLEM - Most common failure seems to be the sending unit. I think your easiest first step is to pull out the sender (under the trunk mat) and determine if the float has failed......full of gas from a pin-hole, etc. If the float has gas in it, try moving the float/arm up and down, with the sender grounded with an alligator clip wire....to see if the dash gauge moves.
If no good results, then the sender or the gauge/wiring may be bad. Try a known good sender (borrowed fro Cliff Green or another club member), then you will know where to look next.......wiring or dash gauge.....neither of which is much fun.
51woodie 09-29-2021 06:01 PM
Re: Gas gauge quit
Clem. I'm not familiar with a '40, but if it is the same fuel gauge system as my '46 coupe, I might be able to add some info. My fuel gauge was not reading full when the tank was full. One thing that I did while testing the gauge system, (you need the ignition on) was to disconnect the power to the coil to prevent damage to the point and/or coil. Another note, when the sender (in my case) is out of the tank, there will be some gas fumes in the area of the tank opening. If the disconnected fuel sender wire touches the tank with the ignition on, it will make a spark. I tested the circuit from the sender to the gauge by using a 2' lead with clips, so I could make the connection away from the tank opening. the gauge will read FULL when the gauge wire is connected to a ground. If you get a reading, the circuit is good, and the sender or float is likely at fault. In my case the float (aftermarket I think) was partially flooded.
Clem Clement 09-30-2021 11:39 AM
Re: Gas gauge quit
Thanks for the important safety tip
Clem
v8nut 09-30-2021 12:40 PM
Re: Gas gauge quit
My original '39 sender has a cork float that is completely saturated with gas and stays sunk on the bottom of the tank. Jim in San Jose
Clem Clement 10-12-2021 01:03 PM
Re: Gas gauge quit
The builder put in a new tank. I'm very slow lately and will get to it when I can. Life is in the way.
Thanks
Zeke3 10-12-2021 09:19 PM
Re: Gas gauge quit
There is an old discussion on here that describes replacing the cork float with two replacement modern composite Model A floats glued together. I haven't tried it yet, but I have the same condition on my 1937 fuel sending unit as yours.
Clem Clement 12-04-2021 10:42 PM
Re: Gas gauge quit
Mine system is supposedly all rebuilt.
petehoovie 12-04-2021 10:58 PM
Re: Gas gauge quit
See this link for the fix > https://fordbarn.com/forum/showthrea...ght=cork+float
https://fordbarn.com/forum/attachmen...3&d=1456426601
Photo shows the removed original cork float and the newly installed replacement float.
Buy replacement float here > https://www.snydersantiqueauto.com/p...9370&cat=41706
https://www.snydersantiqueauto.com/c...s/A-9313-C.jpg
VeryTangled 12-04-2021 11:23 PM
Re: Gas gauge quit
My solution at the time; The one piece that was useful on the repro sender was the float. I grafted it onto the original arm.
TJ 12-05-2021 11:59 AM
Re: Gas gauge quit
Clem, supposed to be rebuilt and knowing it was rebuilt for sure are two different things. It sounds like a float issue, so pull the sender and check the float.
19Fordy 12-05-2021 12:11 PM
Re: Gas gauge quit
6 Attachment(s)
Clem, Remove the sending unit from the tank and cover the opening with a rag to prevent fumes. Then, lay the sending unit on a piece of cardboard away from the tank opening and use an alligator clipped wire to connect the wire from the gauge to the top of the sending unit. Then run another alligator clipped wire from the body of the sending unit to ground (for instance, the trunk floor latch). Then, switch on the ignition and move the float arm thru its range of motion to see if it registers properly with the gauge. If your float is brass, check it for hairline cracks which allow gas to seep in and give false readings. Switch OFF the ignition before you reinstall the sending unit. A Fordbarn SEARCH for Gas Tank Sending unit will yield much more info. The 1940 Ford gas tank sending unit is shown below. 40 Merc is probably the same and both are made by King-Sealy. Neither operates on the OHMs Principle.
https://www.fordbarn.com/forum/searc...rchid=25890535
Clem Clement 02-10-2022 02:49 AM
Re: Gas gauge quit
Thanks
Lawson Cox 02-13-2022 03:34 PM
Re: Gas gauge quit
Replace the float with a brass one. They are readily available.
Lawson
