Horn electrical terminal connection 2 Attachment(s)
Has anyone come up with an improvement for the horn wire connection ?
The wire harness bullet ends are simply pushed into the horn terminals which are not shaped like the female bullet style connectors used elsewhere on the car. Kevin |
Re: Horn electrical terminal connection If it aint broke ...... They have been working for well over 90 years.
Re: Horn electrical terminal connection They are inserted into the clips from the sides, not from the bottom.
Re: Horn electrical terminal connection X2 on post 2.
Re: Horn electrical terminal connection 1 Attachment(s)
X3 on post 2
Re: Horn electrical terminal connection So I had the bullet end shoved into the wrong place. Thanks I will correct this.
Re: Horn electrical terminal connection The clip on the right looks OK but the one on the left looks gimballed up
