The Ford Barn
-   -   Old School Parking brake fixture for stretched cable (https://www.fordbarn.com/forum/showthread.php?t=304176)
GB SISSON 09-22-2021 07:27 PM
I tried searching for this but Mr. Google doesn't seem to remember the JC Whitney/ Western Auto gadget that clamped onto a stretched cable to 'shorten' it. Probably got outlawed. Seen them on the old wrecks I drag home. Do they still make them?
51504bat 09-22-2021 08:23 PM
Re: Old School Parking brake fixture for stretched cable
GB, I may have one in my stash. I'll check and let you know. If I do its ours for postage.
GB SISSON 09-22-2021 08:33 PM
It's actually for my '92 F350. I have had the rear axle mostly apart with new brakes, seals etc after a roadside disaster with perhaps too many beams on the load. Everything works well now, but no matter what, the parking brake doesn't grab until that far left pedal is about a 1/2" off the floorboards. Thanks! A simple device, just puts a kink in the cable to use up length.....
corvette8n 09-22-2021 09:41 PM
1 Attachment(s)
Gary: Rockauto see pic, I think the hook/bolt is in backwards in the picture, I may order one to have on hand.
https://www.rockauto.com/en/parts/do...adjuster,10479
Also carried by advance auto and Oreilly and eBay.
https://www.oreillyauto.com/detail/c...ter/mtm0/03006
bobH 09-22-2021 10:14 PM
If necessary, 'gang' them. I think my old truck has at least two of them.
GB SISSON 09-22-2021 10:33 PM
Sooo Funny!!! and yes the foreign dudes that assembled the thing for the picture got the hook in backwards. Would work fine once reversed, but the ones I've seen have a cast serpentine shape re-routing the cable. I like your's better. OK, to be honest here, my 47 tonner which made a good wood run today had the same problem and in a pinch I cut a couple inches outa the cable and then took a 12" piece of wire rope and cable clamped with 3 clamps each side, a splice that drew the cut ends together. It's a Very good parking brake, but with the '92 running thbe interstate and licensed/insured with my business I thouught it best to do it right. Well , sort of right. Gonna go to Rockauto! I see on Amazon that Dorman has some interesting ways to go about this ...
Bruce of MN 09-27-2021 02:33 AM
Can you link to the Dorman items?
V8COOPMAN 09-27-2021 03:35 AM
Dorman #03006, available at O'Reiley's, etc! DD
https://static.dormanproducts.com/im.../03006-007.JPG
GB SISSON 09-27-2021 10:32 AM
Originally Posted by V8COOPMAN (Post 2060700)
So, are we all in agreement that the hook in the photo is installed backwards?
JSeery 09-27-2021 11:29 AM
2 Attachment(s)
Yep, the two nuts are used to adjust and tight the J-hook and go either side of solid part at the end where the hook is now. The J-hook needs to be between the studs to pull on the cable.
Yoyodyne 09-27-2021 07:16 PM
Yes, pretty sure that's just so it can't separate in shipping.
Interesting, I've always just seen them double nutted on the outside. I can see your point though.
big job 09-28-2021 04:47 AM
I bought a couple last year from Napa and asked this thing is backward he said yes that's for packaging.
