Testing a Dwell Gauge When you are out at a swap meet or garage sale and see a Dwell Gauge, is there any way to test the gauge without a car?
Re: Testing a Dwell Gauge There is no way that I can think of
Re: Testing a Dwell Gauge Quote:
And then "I have a nice all chromed up maybe Snap on." problem is there is no known battery's available for its weird voltage. so it sits in the draw. |
Re: Testing a Dwell Gauge 1 Attachment(s)
Those are always a "risk" buy. You never can predict how internal
electronic components will age. I have an Orbit Laboratories light/dwell/tach meter my Dad got in the early 70's. Still works fine. Nice, because I've seen some pretty pricey old stuff that didn't. |
Re: Testing a Dwell Gauge I guess there is a good way A dwell meter is a calibrated volt meter , carry a 9 bolt in a zip lock snd hook it up should have some needle bump from the battery ???
Thanks |
Re: Testing a Dwell Gauge That's a great idea! At least you know that it "might work" . . . depending on whether or not it needs batteries or a power source itself (most do not).
Re: Testing a Dwell Gauge Next, you might need to figure out a way to calibrate it.
Adjusting the calibration is a whole other can of worms. Usually not cost effective on cheap meters. |
Now we know why guys have multiple meters, some marked good and others marked bad, when you go to a garage sale.:o Never did find an article on how to calibrate them. |
Testing a Dwell Meter If you dig around the intertube pages, you should find what you're looking for. A standard voltmeter can be used to check dwell if you understand what you are looking at, a dwell meter isn't very sophisticated as far as test equipment goes, notice this feature was typically included with simple analog voltmeter/tach units. "Engine Analyzer" they called them. Advertising, I suppose.
