The Ford Barn
-   -   Help Identifying unknown shaft / fork (https://www.fordbarn.com/forum/showthread.php?t=302343)
flybob08 08-11-2021 01:08 PM
3 Attachment(s)
Hi
New to Model A's and am working to get mine in shape. Dealing with lots of missing bolts, nuts, etc. and am not sure If something should be connected the the forks in the upper left of the first photo which is above and behind the battery and cross shaft near the cross member. In picture 2 the shaft fork is right center. In the third picture you can see where the shaft appears to connect to the stop light switch shaft towards the center of the car.
Is something supposed to be connected to the fork by the frame rail on a 28 roadster pick-up?
Thanks
Bob
Flathead 08-11-2021 02:14 PM
Re: Help Identifying unknown shaft / fork
Does your A have a left side emergency brake handle?
Bob C 08-11-2021 02:58 PM
2 Attachment(s)
Check these out.
flybob08 08-11-2021 03:39 PM
It has the pistol style hand brake in front of the stick shift
flybob08 08-11-2021 03:40 PM
I am not seeing the forks in the attached photos. Am I missing them?
Tinbasher 08-11-2021 03:56 PM
Looks like left over parts from the AR brake system. Early 28.
Tom Wesenberg 08-11-2021 10:03 PM
Agree, Ford didn't remove that part of the casting after he changed the location of the parking brake handle.
flybob08 08-11-2021 10:09 PM
Many thanks for the expertise!!
