The Ford Barn
-   -   Front Motor Mount Springs (https://www.fordbarn.com/forum/showthread.php?t=302270)
Oldgearz 08-09-2021 03:26 PM
I have what looks like the original style front motor mount. I have more vibration than I like, so I ordered a rebuild kit. The springs in the kit are much smaller, punier looking than what is now on the car. Question is, where did my current beefier springs come from? Original or some other after-market that is currently not in the supplier's kits?
alexiskai 08-09-2021 03:36 PM
Re: Front Motor Mount Springs
Are your springs connected together? There was a popular kit often called the beehive mount, because the springs bulged in the center like a beehive.
Bob C 08-09-2021 05:21 PM
1 Attachment(s)
If it looks like this it is after market and usually makes the front of the engine
sit to high.
Oldgearz 08-09-2021 06:25 PM
The springs look like the Bob C picture, but I can't see or feel a connection between the too. It may be down under the center mounting bolt. The engine does sit a little high in front. I can't get an original style crank rod to line up. There seems to be a rubber grommet/bushing inside the springs. What should I replace this with if I decide to go that way?
alexiskai 08-09-2021 08:38 PM
Most folks with the beehive springs just go back to bone stock and usually report improvement.
gdmn852 08-10-2021 10:36 AM
1 Attachment(s)
This is what the replacement original type springs looks like,you may also need the bushing
Oldgearz 08-10-2021 10:51 AM
Bushing? Are you talking about what they call the "Front Engine Support Busing ?
katy 08-10-2021 11:01 AM
That's what I did. Those rubbers inside the beehive springs had turned as hard as concrete.
gdmn852 08-10-2021 11:31 AM
Yes, part number A 6034 front support Bushing.Happen to be changing mine right now.It fits from bottom of cross member held in by small spring and nut .
alexiskai 08-10-2021 11:43 AM
The front engine support bushing is the brass washer-shaped part pictured on the right of gdmn852's photo. It's commonly said that Ford discontinued use of the washer around Jan. '29 because it wasn't allowing the engine to move and flex the way it needed to – but I'm not sure where the documentation of this change is. I've only seen it referred to indirectly. It's also not clear how much the removal of this part had to do with the quality of '20s roads, in which case we might not need to remove it.
Ray in La Mesa 08-11-2021 07:46 AM
I have the repro springs with the rubber plugs in the springs, hard as a rock. I took a punch & knocked them out, got lucky, now the engine sits perfect.
gdmn852 08-11-2021 10:55 AM
Hello again, on the car I am working on the bushing must have been missing for awhile,the yoke bolt and cross member hole both show wear. The hardest part to do this job is to keep the springs where they belong and getting lower spring up to get nut started on it,also make the hand crank lines up with crank shaft.
