The Ford Barn
-   -   Rear Wheel Bearing Question (https://www.fordbarn.com/forum/showthread.php?t=301964)
Conaway2 08-02-2021 07:49 PM
Does anyone know where I can find the factory spec for the OD of the wheel bearing surface in the rear axle housing ?
I’m trying to decide whether or not I need to have a new bearing surface pressed on, as the original surface doesn’t look very worn. I’m measuring about 2.620” on each side.
Thanks - Jim
Conaway2 08-02-2021 08:16 PM
Re: Rear Wheel Bearing Question
Thanks - Jim
Never mind - just found the spec on Bratton’s site (2.061 to 2.063”). My measurement is actually 2.062”, so I don’t need to replace the bearing surfaces at this point.
Jim
chrs1961815 08-02-2021 09:11 PM
Glad you found your answer. I have found that it is very hard to mess up rear wheel bearings on a Model A so long as they are kept greased. Most everybody just reuses them.
