The Ford Barn
-   -   Is Cartouche still in business? (https://www.fordbarn.com/forum/showthread.php?t=301944)
Chris Haynes 08-02-2021 01:50 PM
When I go to their website www.cartoucheupholstery.com I wind up on https://www.macsautoparts.com/. My experiences with Macs have been less than stellar. Is Cartouche still in business?
Bob C 08-02-2021 02:32 PM
Re: Is Cartouche still in business?
I think you'll find Mac's owns Cartouche.
rotorwrench 08-02-2021 02:42 PM
Ekler's owns Mac's to make it even more complicated.
McMimmcs 08-02-2021 02:54 PM
Simple, simple. Seek another supplier. I personally, will continue to use Macs because I have never experienced a problem with them.
bobbader 08-02-2021 03:37 PM
As reported, Cartouche is owned by Mac's and always has been. The corporate owner of both is Eckler's. If you have bought Cartouche before, and have been satisfied, the quality remains the same. So, even though you may not be satisfied with Mac's, Cartouche may still fit the bill for you.
BRENT in 10-uh-C 08-02-2021 03:44 PM
Bob, that is a good way to say that. I will say that IMHO the quality is probably up some since they are now the supplier for the same fabrics and piece-goods that LeBaron Bonney used to make. Before, Cartouche did not have access to those materials, and often resorted to using inferior grade materials.
msmaron 08-02-2021 04:06 PM
Ecklers won the auction for the pallets of material from the LaBaron Bonney auction. The sad part is when they got the pallets of material over half was full of mold and destroyed and had to be sent to the landfills as garbage, turns out they were forced to evacuate the building they were in by the landlord with in days, machinery was tossed and mostly all pattens went to the trash also. So they had to store it where they could and turned out to be a wet damp location for almost a year, they are trying to get through what is still salvageable at this time...So at this time they are still using the same materials as before.
duke36 08-02-2021 06:20 PM
I bought some windlace from Mac's that was an exact match to an existing upholstery job that no one else had.
700rpm 08-02-2021 07:18 PM
My experience with Cartouche for a ‘30 PU 15 years ago: the pattern was right, but the material was thin.
chrs1961815 08-02-2021 09:12 PM
I have also heard the material is thin and wears quickly. Most people are putting these kits in drivers so that is unacceptable for a car that is used a lot.
McMimmcs 08-03-2021 06:09 AM
Again an easy solution, don’t buy it !
McMimmcs 08-03-2021 06:25 AM
It is very unfair to make comments “ I have heard”! The comments we should consider credible are “ I personally experienced”.
ronn 08-08-2021 07:08 AM
thumbs up Mc!!!!!!!!
nkaminar 08-08-2021 08:13 AM
For those of you who are redoing the upholstery on a driver and don't care if you have original material, and can do the work yourself or have a local upholstery shop that can do it, try Sailrite. They have a wide selection of material at reasonable prices, some of it is very durable. I like their Ultrasuede. See https://www.sailrite.com/search?keywords=ultrasuede In the past I have used the old upholstery as a pattern.
Tinbasher 08-08-2021 11:14 AM
Check out Classtique Upholstery. I imagine now LB is gone there going to be busy. But they sell a quality product.
diomed 08-10-2021 04:22 AM
Website: https://www.classtiqueupholstery.com/index.php/catalog
oldredford 08-11-2021 07:21 AM
I installed a cartouche in my 1940 coupe. I removed a LB kit that was 20 years old. Side by side LB material has more thread count than Cartouche. So in my opinion LB is a better material than Cartouche. Time will tell but I can tell you it won't last as long as LB. I am doing another uphostery job on my 30 Model a 5 window coupe and I have a local shop that will make me a kit for half the price.
BRENT in 10-uh-C 08-11-2021 01:43 PM
I think you are likely comparing apples to oranges in this. If you are speaking of a decade ago or longer, then the L/B manufactured piece-goods were definitely better. Since Cartouche is now the manufacturer of the piece goods, the quality is the same as what L/B had. Therefore it will last just as long as what a L/B supplied kit would have.
One thing to think about, most likely a local shop will not have access to the correct style fabrics nor the patterns for a 45B. Since the sewing would likely be the same amount of time whether it was done by a local shop or a kit manufacturer, in my mind, the only way that a local shop can do it for half the price is to use inferior materials. Thoughts on that??
