The Ford Barn
-   -   Size square on banjo (https://www.fordbarn.com/forum/showthread.php?t=301863)
Oberfranke 07-31-2021 07:16 AM
1 Attachment(s)
What size is the square on the Banjo (Differential Housing)? (Metric sizes are standard for us)
Thanks in advance
Russell Reay 07-31-2021 07:46 AM
Re: Size square on banjo
Bigger than 3/8", smaller than 1/2", probably 11 or 12 mm. The book says to use a 3/8 drive ratchet. It is pretty sloppy, but a 1/2" drive is too big.
katy 07-31-2021 12:30 PM
1 Attachment(s)
Something like this:
https://www.carid.com/k-tool-interna...eid=3058478643
Chuck Sea/Tac 07-31-2021 07:57 PM
You may have to grind down from the size to big.
Tom Endy 07-31-2021 08:29 PM
The 3\8" breaker bar will usually lock in place and a tap with a hammer will loosen it. Most have been butchered up by people using channel locks or vice grips to loosen them. The suppliers sell a replacement that is actually 3\8" and the breaker bar and socket wrench fit correctly.
Tom Endy
Tom Wesenberg 07-31-2021 08:30 PM
7/16", and if you find a 7/16" square head bolt, that and a Vice Grip usually work well.
dave in australia 07-31-2021 08:37 PM
I bought a cheap brand 1/2" drive extension and ground down the end to 7/16" square. Fits in and I can use a 1/2" ratchet to loosen and tighten the plug. Was a $5 solution.
mleder 07-31-2021 08:54 PM
Buy a piece of 7/16" key stock from a bearing supplier or industrial supplier like Graingers or McMaster Carr. Cut it into sections use one and give the rest to your buddies. Its cheap
McMimmcs 07-31-2021 09:00 PM
A very intelligent solution. Smart thinking on your part !
Kurt in NJ 08-01-2021 06:59 AM
I use the tool that came in the tool kit--- the tail end of the adjustable wrench
Patrick L. 08-01-2021 08:39 AM
Yep, just an old 'shorty' extension. Ground it down to size and been using it for 50 years.
Ray in La Mesa 08-01-2021 09:39 AM
I had a VW lug stud laying around so ground it to fit the square.
Ivan in southeast va. 08-01-2021 02:49 PM
1 Attachment(s)
I have been using a spare 3/8" for years.
