The Ford Barn
-   -   Model A Ford clutch pedal and pedal shaft collar (https://www.fordbarn.com/forum/showthread.php?t=301670)
dceminsky 07-26-2021 03:33 PM
I am making adjustments to the excessive clutch play and am wondering if the brake and clutch pedal collar is supposed to fit snugly between the clutch pedal tabs. I have a fair amount of play when I pin the collar(new) on the shaft and am not sure if this play is normal or are the tabs on the clutch pedal worn?
BRENT in 10-uh-C 07-26-2021 04:05 PM
Re: Model A Ford clutch pedal and pedal shaft collar
Welcome to Fordbarn!
The tabs on the factory blueprint are supposed to be ½" wide on both sides with ¼" depth of the tab. The overall width of the Pedal Shaft Bushing Housing (-not inclusive of the tabs) on the print shows that to be 2.030" wide. Depending on what year you are working on, there is a thin wavy washer that is between the brake pedal and the clutch pedal to keep pressure against the collar. This was typically found on May-June of 1929 until end of production. I hope that answers your question.
