The Ford Barn
-   -   location of rubber window rests on Deluxe Roadster top (https://www.fordbarn.com/forum/showthread.php?t=301654)
Nosetime 07-26-2021 08:28 AM
1 Attachment(s)
Greetings. I am looking for a diagram or pics of the location of the rubber window frame rests for the Deluxe roadster when top is folded down. I want to get as close to proper location as possible - before I drill holes! Thinking a dab from glue gun and double sided tape to stick on window frame and fold down, but want a starting point if someone can help. thanks in advance, Greg.
31steve 07-26-2021 04:11 PM
Re: location of rubber window rests on Deluxe Roadster top
2 Attachment(s)
Here are two pics from my 31 roadster with original panel above deck lid. I would still use your fold down and check method first because whoever put in the window in the top could have been off a bit. https://www.fordbarn.com/forum/window rest 1https://www.fordbarn.com/forum/window rest 2
Charlie Stephens 07-26-2021 09:27 PM
Check underneath and see if someone filled the holes. I thought all of the cars had them. Any chance yours is a reproduction body?
Charlie Stephens
Nosetime 07-27-2021 07:21 AM
1 Attachment(s)
@31steve, thank you, that will give me an idea where to start, but yes will go ahead with my layout plan. Yes Charlie, I have a Brookville body. I started with a rolling chassis from a hotrod builder.
