X Connecting Rod Measurements I am looking for the measurements of an early x connecting rod. Overall length, width, etc. If you have regular original rod too, could you take a side by side pic? Thanks!
Re: X Connecting Rod Measurements I can ship one each to you for $8?
Re: X Connecting Rod Measurements Thanks but I really just need the measurements. If nobody can provide I might take you up on your offer.
Re: X Connecting Rod Measurements It's the same except for the "X" instead of the "H"
Center to center 7.498-7.502 i have a later print (H type) that calls out weight specs small end ,198 +/- 1 gram, large end 512 +/- 1 gram |
Re: X Connecting Rod Measurements Is the dipper the same? Thanks.
