The Ford Barn
-   -   Model A Rear End Ratio (https://www.fordbarn.com/forum/showthread.php?t=301317)
Afordman31 07-17-2021 08:06 PM
2 Attachment(s)
Jacked up the drivers side rear wheel, put a piece of tape at the 6 o'clock position. Put a mark at the 12 o'clock position on the drive shaft splined end.
I then turned the rear wheel forward one full revolution and the driveshaft moved not quite 1 7/8 turns clockwise. What ration rear end do I have? Your help is much appreciated!
Patrick L. 07-17-2021 08:13 PM
Re: Model A Rear End Ratio
I would think it should be a 3.78.
jayvee34 07-18-2021 06:40 AM
Math wise: 2X1.875=3.75 Most likely a 3.78
alexiskai 07-18-2021 06:57 AM
I believe you’re supposed to rotate the rear wheel twice and then note the drive shaft revolutions. Multiplying your current result by 2 gives 3.7, which I guess is a possible result if you have an early ‘28, but otherwise you should keep going to get a more precise answer.
nkaminar 07-18-2021 07:09 AM
If you want to be really precise, count the driveshaft revolutions with 20 rotations of the wheel and then divide by 10.
Patrick L. 07-18-2021 08:57 AM
I think the ratio available at the time were 3.70 [early], 3.78 [later] and 4.11 [truck]. I think by far most had 3.78.
But the difference between 3.7 and 3.78 won't be noticeable.
Afordman31 07-20-2021 10:11 PM
Thank all of you for your replies. Appreciated!
