The Ford Barn
-   -   Trouble with repro light switch rod (https://www.fordbarn.com/forum/showthread.php?t=301261)
Bud on the Vineyard 07-16-2021 04:32 PM
I'm installing a seven tooth steering column in my early 29 Station Wagon (just to be correct). Unfortunately the reproduction light switch rod seems to be too large in diameter to drop down the steering shaft. Has anyone encountered this problem before?
katy 07-17-2021 11:25 AM
Re: Trouble with repro light switch rod
Could the top of the shaft be "mushroomed" (squinched?) in a little? Have you tried it at the bottom end?
Bud on the Vineyard 07-17-2021 04:10 PM
I'll check for obstructions, burrs, etc. The square end of the horn rod will insert about a half inch. When the round cross section is encountered it binds. One suggestion was that these reproduction rods need to be sanded with 80 grit at the transition from square to round cross section. I'll work on it.
jw hash 07-17-2021 05:15 PM
sometimes someone uses the wrong wood drift key on the wheel. the wood drift key needs to be flat on the bottom, or you will push the slot down on the horn rod. take at 25/64 drill bit and run it down from the top it will open the shaft up to the right size.
Bud on the Vineyard 07-17-2021 05:57 PM
My wheel is a spline but thanks for the drill size info. I'll try that.
katy 07-19-2021 10:58 AM
Originally Posted by jw hash (Post 2037009)
wood drift key
try: woodruff key
