Model A Transmission I have a guy that is going to go thru my engine, now I'm looking for someone to rebuild the transmission for me. Would even purchase one if I could already rebuilt. I live just north of Indianapolis In, but willing to drive a little. Thanks
Re: Model A Transmission If I were spending your money, I would be tempted to get a Mitchel synchronized transmission.
If I'm spending mine, I'd rebuild it myself. |
Re: Model A Transmission Try Van Pelt Sales. They are located in Milford, OH, so not all that far from you. They are the go to source for many early Ford parts. Their web site says they do transmissions from 1928 to 1962.
http://www.vanpeltsales.com/FH_web/f...ans-repair.htm VANPELT SALES LLC 1081 State Route 28 Bypass - Suite 258 Milford, Ohio 45150-2090 1-513-724-9486 |
Re: Model A Transmission Go to YouTube, There are video's of how a Model A transmission works, and video's of
how to disassemble, and rebuild them. If you have any mechanical ability at all, just follow the instructions and you can do it and have a feeling of accomplishment and gain a whole lot of confidence. John |
Re: Model A Transmission I can help if desired I am in St. Louis. I believe have a rebuilt on hand or I can do yours.
I do service and restoration work and Advertise in Model A News and Restorer. Larry Shepard |
Re: Model A Transmission Overhauling a Model A transmission is not difficult. You just need to be aware of the traps Henry laid for you. The attached link should be of help.
Tom Endy https://www.santaanitaas.org/wp-cont...ugust-2018.pdf |
Re: Model A Transmission Quote:
https://live.staticflickr.com/65535/...1a69f74572.jpg |
Re: Model A Transmission I don't know about a complete rebuild, but back i n the day (I was 15 or 16 at the time) I took a Model A transmission apart, replaced a couple of gears that were broken and re-assembled it. Worked great. Bought the gears from NAPA.
Re: Model A Transmission Definitely entertain a Model A trans rebuild as a DIY project. Replacement parts are readily available and no special tools required to do the job. Do some homework, review a few Youtubes and you are good to go. Need to be aware of the continuing issue with replacement roller bearings and have a plan in advance. Much data on the topic on the forum. Good Luck.
Re: Model A Transmission The A bone transmission is as simple as they get since there are no synchronizers in there. With the exception of some bearings, most parts are reproduced with decent quality. A person has to find the right people to supply new bearings since some of them are problematic.
Re: Model A Transmission You might start with Brattons or Arizona Model A for your parts...Ernie in Arizona
Re: Model A Transmission Thanks everyone for your input, may go ahead and do it myself. Just want it done right so as not to have to pull it again, and as few leaks as possible. How do you know if the gears need to be replaced or not? Again thanks
Re: Model A Transmission I rebuilt a Model a Trans out of the back of my truck during a lunch brake at work. I was in a parking lot down the road. Easier than legos. I did not do the shift tower at the same time. It really is that easy.
