The Ford Barn
-   -   40 stumbles when braking. (https://www.fordbarn.com/forum/showthread.php?t=297444)
DMMuir 04-17-2021 04:59 PM
So my 40 is running rough when slowing and braking. Clutch is fully disengaged and the engine runs rough and slow until I am fully stopped, then smooths out and speeds up to normal idle. Occasionally it will die but restart fine.
Thoughts?
Ggmac 04-17-2021 05:02 PM
Re: 40 stumbles when braking.
Check float level
V8COOPMAN 04-17-2021 05:16 PM
Originally Posted by ggmac (Post 2008167)
check float level
x2! Dd
Bored&Stroked 04-18-2021 04:09 PM
Also check and make sure that the engine has a good ground with the chassis - as I've seen cases where the movement of the engine changed the ground surfaces and caused an ignition issue. If it is not the float level, you might consider a large ground wire from the frame (ground cable location) to a transmission or head bolt.
