Vin location on a 1951 Ford Custom Deluxe Club Coupe Need help with location of 1951 Ford custom deluxe coupe vin#. I know of the plate on the firewall that contains the production code and serial number, is there a number stamped in the frame or elsewhere to identify the particular ID #.
Thank You! |
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe The serial number is stamped on the frame rail in a couple of places. It matched the number on the firewall plate on my car.
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe 1 Attachment(s)
This is on the passenger side front top rail
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe Where are the numbers stamped in the frame rail? on the passenger front in the engine compartment?
Thank you! |
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe Thank You!
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe Also check the right side frame cross brace that runs from the frame to the front crossmember under the radiator.
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe Will do.
Thank You! |
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe Quote:
Re: Vin location on a 1951 Ford Custom Deluxe Club Coupe And hidden on the passenger side, behind the hood hinge there could be a data plate with the vin also stamped on it.
It's there on my 1949 and also a friends 1950. |
