37 Ford steering wheel and column What would be the correct colors for the banjo wheel and column?
Thanks. FYI I did a search and spent an hr looking at every other steering wheel question....I gave up |
Re: 37 Ford steering wheel and column The steering wheel hub and the column were painted Rustic Brown. That info can be found on page A-15 and 3-15 of the V-8 Club's 1937 Book. Page 3-15 just says brown but A-15 references Rustic Brown. If you don't have the book and are doing a '37 you should own that book. www.earlyfordv8.org.
Re: 37 Ford steering wheel and column Thank you TJ. Not restoring a whole car, just steering wheel and column for my early hot rod.
Re: 37 Ford steering wheel and column 1 Attachment(s)
Here's the brown in question.
Re: 37 Ford steering wheel and column Brown for '37 deluxe - black for standard.
Re: 37 Ford steering wheel and column https://www.fordbarn.com/forum/attac...p;d=1615468440
Another very helpful picture by DavidG. What a perfect example of what the interior on the 1937 Ford Deluxe should look like. |
Re: 37 Ford steering wheel and column https://www.fordbarn.com/forum/attac...p;d=1615524322
This is what the exterior of that nice 1937 Ford Convertible Cabriolet looks like. Perfection. |
Re: 37 Ford steering wheel and column Quote:
