The Ford Barn
-   Model T (1909-1927) (https://www.fordbarn.com/forum/forumdisplay.php?f=2)
-   -   Adding air filter? (https://www.fordbarn.com/forum/showthread.php?t=295056)
Kajtek1 02-27-2021 11:03 AM
Adding air filter?
I see in catalog air filters, what I guess are for newer models, but did anybody try to add air filter to his T ?
Living in Las Vegas I don't care about intake air warming, but sand dust is the issue, so at this point I am trying to figure out if I can use the T for grocery getting, or just as a show car.
J Franklin 02-27-2021 04:16 PM
Re: Adding air filter?
You can use a non restrictive filter but keep it clean, your car may run a slight bit more rich. You really need to get to know your car before adding any accessories beside a rearview mirror and pedal extensions. Maybe a gas gauge wouldn't hurt.
Btw, my aunt and uncle were Vegas pioneers. They moved there when the dam was being built. George Harris was a teacher and became Superintendant of schools, I think there is a school named for him. I used to go there often and saw an A bomb test once! My cousin Joel had one of the first sailboats on the lake.
redmodelt 02-27-2021 04:32 PM
Do a search of "mtfca air filter" there are lots of ideas out there, including using sink drain parts. :)
Kelly mt 02-27-2021 09:36 PM
I run a lot of logging roads and I run an air filter on all my T's. After a 500 mile tour most of which is dirt you'd be amazed how much crap that filter catches.
Kajtek1 02-28-2021 01:16 AM
What filter do you use Kelly?
Retiring from house remodeling left me with big bucket of drainage pipes, so looks like I have 1/2 of the system already :cool:
Kelly mt 02-28-2021 10:25 PM
2 Attachment(s)
I'm using two types, one is the spring loaded foam unit and the other has a casting that allows use of a K&N element. The K&N unit came on my speedster so I don't know where you can find one. The other is from Lang's.
Kajtek1 02-20-2022 01:15 PM
I finally add an air filter that I found at local AutoZone and it seems to work fine, however after estimated 60 miles drive, the filter is clog and took me quite a while to figure out why my engine would start, make few turns and die.
I am ordering new replacement and below is the insert I am using but is it normal for the engine to mix the oil and dust to clog the filter in only 60 miles?
It is small filter, but replacing it every 50 miles is not going to be fun.
There is no visible dust on old filter, but it changed the color thanks to oil contamination.
https://www.autozone.com/intake-syst...ter/228334_0_0
Kajtek1 02-20-2022 01:21 PM
Here is link to whole assemble, who combined with chromed parts from sink P-trap and some holding brackets make the new filter
https://www.autozone.com/intake-syst...artNumber=true
