The Ford Barn
-   -   Holley carburetor with S.W. heater gas feed picture (https://www.fordbarn.com/forum/showthread.php?t=293710)
Lawson Cox 01-29-2021 02:27 PM
HELP: I have an installation kit for a Southwind heater that I believe is designed for a Holley carburetor but I am not certain. I know it will not work on a Stromberg. I can't post pictures here so I can't show you what I have. Does anyone have a picture of a Holley with a Southwind heater set up? Also, I have a vacuum plate I know is for a Stromberg. Will it work with a Holley? Thanks, guys/gals.
expavr 01-29-2021 04:01 PM
Re: Holley carburetor with S.W. heater gas feed picture
4 Attachment(s)
Lawson. Attached are photos of the SW Heater fuel transfer device on a Holley 94. Its been a while since I did this but as I recall I used the directions that came with the heater and the only deviation was to dab on finger nail polish to seal the opening around the tube where it penetrates the carb.
Lawson Cox 01-29-2021 04:30 PM
Thanks expavr, and to Mike Dutkiewicz who sent me a PM with pictures. Both show the "traditional", for the lack of a better word, gas pickup that draws gas from the top of the float bowl. The kit I have provides a larger gas pick or feed tube that connects to the bottom of the float bowl and circles back up to the top where the small gas tube running to the heater carburetor attaches. When my Grandaughter comes by again I'll have her take a picture of a picture I have showing this setup, and then I'll email it to someone who has the skills to post it here. Perhaps that will help. I am just assuming the carb in this picture I have in this picture is a Holley. It sure isn't a Stromberg 97. Lawson
51 MERC-CT 01-29-2021 04:57 PM
Just a thought, S.W. heaters were and are used in aircraft.
As I recall they were hard plumbed into the fuel supply/source and were not just a tube placed into a hole drilled in the top of the fuel bowl.
Lawson Cox 01-29-2021 09:17 PM
Yes, SW did provide a gas heater for aircraft, but they are a totally different animal. Thanks anyhow.
1952henry 01-29-2021 09:19 PM
Somewhere I have a fixture that was attached to the bowl with use of a special jet plug for a 94. Will try to stumble onto it.
Lawson Cox 01-29-2021 09:26 PM
UPDATE: Yes, it is a Stromberg 97. I'll try to post photos or get them posted showing this pickup on a 97 to clear up matters in the minds of anyone who might be interested. BY THE WAY, does anyone have one of the "traditional" gas pickups for the SW heater? Thanks.
Lawson Cox 01-29-2021 09:32 PM
Thanks, 52henry, any help appreciated.
JSeery 01-29-2021 09:36 PM
2 Attachment(s)
Lawson, do you have the installation sheets? I have some of the pages from one posted on the HAMB. Here are the ones on the carb setup. As I read it, there are two ways to set up the fuel connection. One is a through a hole drilled in the top of the float bowl. The second looks to me like it mounts on the carburetor and also directly into the fuel line from the fuel pump.
expavr 01-29-2021 11:24 PM
There may be one in my SW stash. I'll check tomorrow and PM you if I have one.
Les Williams
Lawson Cox 01-30-2021 01:07 PM
Yes JSeery. I have those instructions. Thanks anyway.
Lawson Cox 01-30-2021 01:09 PM
Les Williams
Thanks, Les. I too have quite a few NOC SW parts I need to get rid of.
1952henry 01-31-2021 05:03 PM
I found the fitting, Lawson. Sent you a pm
Lawson Cox 01-31-2021 08:22 PM
Got it and responded. Thanks.
1952henry 01-31-2021 09:18 PM
https://www.flickr.com/photos/191513...posted-public/
I have not seen another fitting like this.
Lawson Cox 02-02-2021 10:36 PM
That's like the one I have (had). I was not familiar with it either, but apparently, it works from what I've seen and read. Thanks for all the help guys. I've learned something from y'all, AGAIN.
