The Ford Barn
-   -   Fuel pump (https://www.fordbarn.com/forum/showthread.php?t=293526)
Wayne B 01-25-2021 04:55 PM
Fuel pump
Hello, I have a 1950 F3 flathead V8. Just had the motor rebuilt, now I have fuel pump issues. The fuel pump won’t last long. Does anyone have any suggestions on this manner? Any help would be greatful.
Thanks,
Wayne
Lawson Cox 01-25-2021 05:13 PM
Re: Fuel pump
What makes you think one has a direct relationship with the other in this regard? Inquiring minds want to know.`
Wayne B 01-25-2021 05:25 PM
Re: Fuel pump
Never had this issue before the rebuild of the motor.
Phil Gillespie 01-25-2021 05:32 PM
Re: Fuel pump
Is your fuel pump a mechanical or electrical.?
Push rod problem if mechanical fuel pump.
try fitting a pressure gauge at discharge to carb, you are looking at around 2 psi ideal.
Phil NZ
FortyNiner 01-25-2021 05:32 PM
Re: Fuel pump
How does the pump fail?
flatjack9 01-25-2021 08:10 PM
Re: Fuel pump
I've had the same pump on my engine for many years.
Will D 01-25-2021 08:37 PM
Re: Fuel pump
Mechanical pump the rubber diaphragm deteriorates and cracks over time. I rebuilt the one on my '38 and the rubber was just starting to show multiple crack stress marks, caught it before it went. If rebuilding, use the original stock spring if still in good condition as the new ones in the rebuild kits are bigger and stronger. They will build to much pressure and cause a leaky carb.
