The Ford Barn
-   -   roof replacement (https://www.fordbarn.com/forum/showthread.php?t=290087)
packrat6 11-13-2020 09:16 AM
roof replacement
Next project on my '30 fordor is replacing the roof material. There seems to be a lot of differing opinions on what materials to use and where they go.
My questions are:
Should there be a fabric layer between the ribs and the chicken wire? If so, what fabric?
Should there be a fabric layer between the chicken wire and the padding? If so, what farbric?
What is the best sealant to use around the edges of the vinyl and on tack heads?
I understand there is a good video covering this install on "abarnyard" but cannot seem to access it. Suggestions on how to access OR on another video option?
Input appreciated.
BRENT in 10-uh-C 11-13-2020 09:46 AM
Re: roof replacement
My questions are:
AShould there be a fabric layer between the ribs and the chicken wire? If so, what fabric?
BShould there be a fabric layer between the chicken wire and the padding? If so, what farbric?
CWhat is the best sealant to use around the edges of the vinyl and on tack heads?
Input appreciated.
A: No fabric is necessary between the ribs and the wire. You can use friction tape in this area if you like.
B: A heavy Duck Muslin cloth. I typically use 10 oz. This is just to support the Cotton padding.
C: Any rubberized Seam Sealer (available at automotive body shop supply stores) is good. It is typically frowned upon to use Silicone as it sometimes promotes rusting of the sheetmetal.
D: I never knew that Marco had any videos on his website.
1930artdeco 11-13-2020 10:17 AM
A shameless plug for my club:) But the Diablo A's put out a video on how to do a top on a 31 slant which you can buy through MAFCA, vendors or download on our website.
Mike
Tacoma Bob 11-13-2020 11:00 AM
Indeed, Marco had the best tutorial I have ever seen.
Bob C 11-13-2020 11:09 AM
Here's a link to Marco's tutorial. https://web.archive.org/web/20140906...finstall-1.htm
Ed in Maine 11-13-2020 11:16 AM
Now I know some of you are going to yell at me for not using original materials but on the tops I have replaced I used 1/2 in. galvanized metal cloth (it is a mesh with 1/2 in. square openings). It is much tougher than chicken wire and less apt to get a depression if something falls on the top. Ed
packrat6 11-13-2020 01:16 PM
thanks for the link bob C. it hooked me up......don't know why the other links i used didn't work but maybe because my computer is older than the car i'm working on.
