The Ford Barn
-   -   Ford Banjo Ring Gear Carrier ID (https://www.fordbarn.com/forum/showthread.php?t=289638)
Hairycanary 11-03-2020 05:53 PM
1 Attachment(s)
I am assembling a 1940 banjo from parts I have collected. Just found this ring gear carrier, but it looks different than others I have seen.
Can someone ID what year it is from?
Thanks,
Dave
rotorwrench 11-04-2020 03:17 PM
Re: Ford Banjo Ring Gear Carrier ID
With the size of the photo, it's hard to tell. They made the same basic assembly from 1932 through 1948 but there may be variations in appearance. The main thing is that they have the same dimensions for the bearing, bolt pattern, and overall length from the ring gear attach face to the lip on the bearing journal where the bearing seats.
The ones I have, have number casting marks like 18 in one spot and 4206 on another in between the special bolt heads. There is also a foundry mark on there too. The part numbers for the two halves were 18-4205 and 18-4206. If it has a B then it would likely be the model A/B type part with the B prefixes if made after the start of model B production.
Ronnieroadster 11-04-2020 03:22 PM
Looks like the typical 1940 to 1948 carrier assembly. The earlier carrier hub diameter the long round area where the bearing is located at the end is a smaller diameter outside its noticeable just by looking at the two assembly's. Then there's the 1932 carrier which is completely different.
Ronnieroadster
Hairycanary 11-04-2020 03:28 PM
Thanks Rotorwrench! Very helpful. Good to know they all have the same bolt pattern and dimensions. I will check the casting marks and see what it has.
Hairycanary 11-04-2020 03:29 PM
Thanks Ronnie for the additional info. Sounds like I can run it in my banjo.
