The Ford Barn
-   -   Engine mount bolts torque (https://www.fordbarn.com/forum/showthread.php?t=289376)
Clem Clement 10-29-2020 05:23 AM
I'm chasing a vibration and thought I'd recheck the torque on my engine mount bolts. I don't want to flatten the donuts unnecessarily. 25 pf correct?
JM 35 Sedan 10-29-2020 07:41 AM
Re: Engine mount bolts torque
Clem, I've never set those engine/transmission mounts, with rubber donut motor mounts to a specific torque reading. I usually tighten the nut to the point where the cotter pin can be inserted.
19Fordy 10-29-2020 10:45 AM
1 Attachment(s)
Tighten nut down until you feel the resistance of the biscuit. Then tighten until you can insert the cotter pin. For some reason my 40 has acorn nuts. They were there when I bought the car in 1963.
Clem Clement 10-29-2020 11:19 AM
thanks!
Clem
Mart 10-29-2020 11:22 AM
19Fordy: They're Kingpin locking bolt nuts.
19Fordy 10-29-2020 11:33 AM
Thanks Mart. I never thought of that. I know the front suspension was replaced before I bought the car but, never thought of king pin locking bolts.
They have worked fine.
tubman 10-29-2020 02:40 PM
They look spiffy, too!
19Fordy 10-29-2020 10:16 PM
Thanks. iIlike that word "spiffy", I use it a lot and people think I'm living in the past.
You and I are probably the few who use it.
Clem Clement 10-30-2020 12:30 AM
I haven't used "spiffy" in a long time. Let me try:
"Charlie, that is a spiffy chic you brung to the dance..." no,no,no: That is incorrect. "Charlie, that is a spiffy Ford you are driving." ah!
Clem
Clem Clement 10-30-2020 12:32 AM
ah!
Clem
Clem Clement 10-30-2020 12:37 AM
I found I had to tighten the nus a good bit to expose the cotter pin holes.
Thanks, Clem
