Chassis painting Does anyone out there know if the chassis parts were painted before assembly individually or, for example, was the rear axle assembly painted after assemble?
Thank you in advance for your input!! |
Re: Chassis painting Some were painted before assembly and some, such as the rear end, were painted after assembly. We're talking many different components with many different finishes on the chassis.
Re: Chassis painting Painting was done to all painted parts before installing them onto the frame.
Re: Chassis painting How do you guys know this stuff!!??
Re: Chassis painting Was the frame dipped or sprayed?
Re: Chassis painting Quote:
Re: Chassis painting 4 Attachment(s)
. . Quote:
Re: Chassis painting I use gloss black Rustoleum enamel . While its not necessary , I add hardener for appearance and durability .
Re: Chassis painting Right On Terry...
Makes a big difference in my mind as one would result in the entire rearend being painted black and the second what we would call "detailed" with the painted components black and the hardware, etc. a different finish. Just a thought. |
I think it often falls in alignment with C.S, Lewis' quote about doing the right thing when no one is looking. :D :eek: ;) Actually, I think it really boils down to what is happening to the hobby as a whole. Somewhere along the way, the mindset has changed from 'Restoring' (returning something exactly as it was in a previous timeframe) to a mindset of 'It is my car and I will do it however I want.'. It is never wrong to do the right thing, ...and generally it is considered 'right' when all of the bolts are reinstalled, when the paint colors are authentic, and .... :rolleyes: |
