The Ford Barn
-   -   Rear wheel bearing dimension (https://www.fordbarn.com/forum/showthread.php?t=287952)
Conaway2 09-30-2020 07:34 AM
Does anyone know what the factory spec inner diameter of the rear bearing housing is ?
Thanks - Jim
katy 09-30-2020 10:18 AM
Re: Rear wheel bearing dimension
Do you mean the ID of the hub, where the bearing rides? Or?
Les Andrews book says: ID of wheel hub - 3.188" - 3.190" - min 3.185"
Conaway2 09-30-2020 12:37 PM
Katy - thanks - that’s exactly what I needed. My drum measures 3.182”.
Jim
