The Ford Barn
-   -   Interior tacks (https://www.fordbarn.com/forum/showthread.php?t=287784)
Standing Elk 09-26-2020 09:59 AM
Interior tacks
How do you hide the heads of the tacks when installing the strips above and to the rear of the doors on a 30 coupe. I need to install new wind lace and will need to remove these pieces to do so. Thanks
duke36 09-26-2020 11:46 AM
Re: Interior tacks
Suggest using brads with the smallest heads possible. Drive only far enough to set the panel below the material surface, then pull material out above head with a needle.
