The Ford Barn
-   -   Front Spindle Measurements (https://www.fordbarn.com/forum/showthread.php?t=287665)
Cape Codder 09-23-2020 06:28 PM
Can someone give me the diameter of the front spindles at the rear wheel bearing as well as at the outer wheel bearing?
1930-Pickup 09-23-2020 09:19 PM
Re: Front Spindle Measurements
Do you mean 'inner'?
Are you looking for the Ford spec, or what people have measured?
It helps to know what you're working on.
Are you troubleshooting the fit of bearings to spindles?
If so, to find the problem, you would need the Ford specs, which I don't have.
katy 09-24-2020 10:52 AM
Here's some part numbers, you can probably pull up the dimensions using these numbers:
Front wheels
A–1201 Front wheel inner race 15250 Timken
A–1202 Front wheel inner bearing 15118 Timken
A–1216 Front wheel outer race 09196 Timken
A–1216 Front wheel outer race 09194 BCA Federal Mogul
A–1217 Front wheel outer bearing 09074 Timken
A–1217 Front wheel outer bearing 67048 LM
Doug Linden 09-25-2020 04:24 PM
Joe, just measured a spare I had.
inner = 1.189"
outer = .750"
Hope this helps.
Cape Codder 09-26-2020 09:39 AM
katy - Thanks for the P/N information!
Doug Linden -Thanks Doug for the measurements!
