The Ford Barn
-   -   Roadster Dash Screws (https://www.fordbarn.com/forum/showthread.php?t=287521)
Krylon32 09-20-2020 05:24 PM
What threads are the screws that hold the dash to the body in a 32 Ford Roadster?
glennpm 09-20-2020 06:23 PM
Re: Roadster Dash Screws
12-24 I believe. David will be along shortly ��
35fordtn 09-20-2020 07:41 PM
They are a 12-24 binding head screw 5/8” long.
DavidG 09-20-2020 09:09 PM
Yep, nickel plated.
PeteVS 09-21-2020 05:27 AM
If you have a screw in hand, and want to be able to know its nominal "number" size, there's a formula for that. The nominal size is the "number" of the size multiplied by .013 and then added to .060. That nominal size is actually the maximum size of a tap so the screw would be a couple of thousandths less. In this case, a #12 screw would be (12 x .013) + .060 = .216. So if you put a micrometer or a pair of calipers on the screw, you should expect them to read about .212 to .215 or so. A #6 screw would be (6 x .013) +.060 = .138 or so.
