The Ford Barn
-   -   Solid Spindle Connecting Rods (Tie Rods) (https://www.fordbarn.com/forum/showthread.php?t=286519)
Steve Plucker 09-01-2020 08:13 PM
Has anybody ever run into SOLID Spindle Connecting Rods or Tie Rods which may have been used during the Model A Ford production period?
And if so...Just how did you determine it was SOLID and not a tube?
Thanks.
Pluck
1955cj5 09-01-2020 10:01 PM
Re: Solid Spindle Connecting Rods (Tie Rods)
1 Attachment(s)
My 29 ccpu had a solid tie rod.
Of course it may have been changed out at some point....but we've owned it since 1962.
It is worn part way through....picture attached...
Would a factory installed part be marked in any way?
katy 09-02-2020 10:47 AM
Ford like to put their name on as many parts as possible, so it's possible, if it's original, that it has "Ford" on it somewhere.
1955cj5 09-02-2020 01:14 PM
I'll go get it and clean it up and see what I find......film at 11.....
1955cj5 09-02-2020 02:58 PM
2 Attachment(s)
I was wrong.
It is not solid.
I could find no letters or numbers on it.
I'm lucky I changed it for a new solid repo replacement.
The old rod/tube is .701" in diameter, but the worn area is only .542".
I was able to easily drive a punch through what little tube remained in that worn area.
You can also see that the end is capped.
Steve Plucker 09-02-2020 08:21 PM
Originally Posted by 1955cj5 (Post 1926823)
I was wrong.
It is not solid.
Not "capped" but about a 3 inch plug.
Pluck
