The Ford Barn
-   -   Clutch Recommendation (https://www.fordbarn.com/forum/showthread.php?t=286230)
Admiral 08-26-2020 09:09 PM
I'm working on building an engine for my '51 Crestliner. It will have a 4-inch crank, a mild overbore, probably EAB heads for an extra shot of compression and an Isky 1007B camshaft. I will also run it with overdrive. Will the stock, 9.5-inch clutch be able to handle the extra torque of this setup or should I plan on getting a larger clutch? If something bigger is recommended, what style/size should I look for?
19Fordy 08-26-2020 09:31 PM
Re: Clutch Recommendation
I had a 10 in clutch in my 40 with a 296 flatty.
Worked fine. I didn't abuse it.
9.5 will also work fine. All depends how you drive it.
JSeery 08-26-2020 09:41 PM
If you interested in acceleration, the smaller the diameter of the clutch assemble the better. If you think you need increased clamping force you can have stiffer springs installed.
cas3 08-26-2020 11:14 PM
9" long style clutch in my 59a with merc crank and a columbia slips if i floor it. i believe on your 8ba flywheel, a borg an beck diaphragm style is used, and perhaps has better grabbing power? so a 9 1/2 " would work?
Ray Balukas 08-27-2020 02:49 AM
Fort Wayne Clutch get 9" with heavy duty springs. Call them and talk to Kerry. He is very familiar with this. I have this set up in my Panel. Works great.
Admiral 08-27-2020 09:11 AM
Thanks, guys. Sounds like the stock clutch will work, especially if I get stiffer springs put in. When the time is right, I'll reach out to Fort Wayne Clutch about getting the stock unit reworked.
solidaxle 08-27-2020 01:10 PM
1 Attachment(s)
Here's some info from The late "Rumbleseat", aka Paul Garrigan.
solidaxle 08-27-2020 01:20 PM
Based on Paul Garrigans article. I went down to a 9 inch clutch and lightened the flywheel by 7 to 8 lbs. to lower the rotating mass. Since I'm I going by seat of pants feeling from last year, I can't say it greatly improved the motor from spooling up quicker. However, I do not have any slippage with the smaller clutch.
Admiral 08-27-2020 03:45 PM
Ah, thanks for sharing this! It's very valuable.
