The Ford Barn
-   -   Bolt Torque ft.lbs. information (https://www.fordbarn.com/forum/showthread.php?t=285976)
dlfrisch 08-21-2020 08:24 PM
Where can I obtain torque ft.lbs information for certain areas on my A ?
jw hash 08-21-2020 08:53 PM
Re: Bolt Torque ft.lbs. information
Bratton`s parts catalog has a lot of the torque specifications in the front pages.
Bob Bidonde 08-22-2020 09:08 AM
There are no original factory torque specifications for the Model "A" because Model "A" production predated the use of the torque wrench. What many use today are torque values from a chart published by the SAE for various bolt sizes and thread pitches.
Jack Shaft 08-22-2020 09:17 AM
Torque values are used to set the fastener in tension,insuring the fastener is providing maximum clamping force to the assembly.
Torque values are determined through testing for accurate results,the steel design of the fastener makes the torque value unique.
Generic torque values,such as the ones Bob cites that are used on Model A engines, are not necessarily accurate.
A 2 B 08-22-2020 10:08 AM
2 Attachment(s)
I received this complimentary pen with my recent order from Mike's "A" Ford-able Parts along with a thank you note. I thought it was cool. You pull the metal tab and the page scrolls out of the pen.
