60 Amp Alternator Has anyone ever purchased and installed a 60 amp generator from Millworks Hot Rod and Supply Co. before? I am having an issue with the tensioner bolt that is supposed to thread into the timing gear cover. Could someone with this alternator kit measure the length/diameter of the mounting bolt supplied for the tensioner bracket? Thank you! Nick
Re: 60 Amp Alternator Can you call Millworks? They may send you a new bolt. Just a thought. Chap
