The Ford Barn
-   -   40 horns (https://www.fordbarn.com/forum/showthread.php?t=285098)
DMMuir 08-04-2020 06:32 PM
40 horns
Can someone post a pic or two showing original Horn location/mounting?
The horns for my car came in the parts box.....
JSeery 08-04-2020 08:33 PM
Re: 40 horns
I'm no expert on 1940s, but it might make a difference between std and dlx.
deuce_roadster 08-04-2020 10:57 PM
Re: 40 horns
If you are talking about a passenger car, deluxe or V8 (std) they mount on the inside of the LH inner fender panel, the bracket has 2 bolts into the panel and 1 into the frame.
V8COOPMAN 08-05-2020 12:47 AM
Re: 40 horns
Two or three pics for ya! DD
http://pddealerphotos.s3.amazonaws.c...211_8464_3.jpg
https://images49.fotki.com/v629/phot...577002X-vi.jpg
https://cdn1.mecum.com/auctions/fl01...?1296241397000
DMMuir 08-05-2020 06:14 AM
Re: 40 horns
Thanks guys. It looks like I have the wrong horns
Kube 08-05-2020 07:33 AM
Re: 40 horns
1 Attachment(s)
This is what you seek...
DMMuir 08-05-2020 07:42 AM
Re: 40 horns
How hard are they to find, and how expensive? It does explain that relay mounted there though
marko39 08-05-2020 07:59 AM
Re: 40 horns
My friend has a set of 39 deluxe horns he would sell. They look like the ones in Kubes pic. Just not as nice. If they are the same I can find out how much he wants.
Kube 08-05-2020 08:16 AM
Re: 40 horns
Nice horns? You see them all over the ($$$) place. realistically, a NICE set that needs refinishing but is not bent or pitted badly is around $100.
1939 horn sets will fit and function quite perfectly in your '40. However, the '39 horns did not have that angled bracket on the back until very late in the model year. If concourse is not a priority, '39 horns will be great for your needs.
Be careful as '41 horns appear at quick sight to be the same as '40. The bracket is different and will not fit your car.
DMMuir 08-05-2020 10:18 AM
Re: 40 horns
Thanks lube
Marco will you check with your friend?
marko39 08-06-2020 08:07 AM
Re: 40 horns
Originally Posted by DMMuir (Post 1916973)
Thanks lube
Pm sent
