Throw out bearing Does the Model A use the same TO bearing as Model B and early V8?
Been searching but can't really find a straight answer to my question. |
Re: Throw out bearing Same bearing 28 through 48.
Re: Throw out bearing Great, thank you.
Re: Throw out bearing Got one more question, does the B-trans use the V8-style bearing hub or the longer Model A-style hub?
When used with B-engine and B-flywheel. |
