The Ford Barn
-   -   Horn rod in a 30 deluxe sedan (https://www.fordbarn.com/forum/showthread.php?t=283954)
old31 07-12-2020 06:17 PM
Is there enough headroom to pull a horn rod out of a 30 deluxe sedan without messing with the steering box?
Marshall V. Daut 07-12-2020 06:56 PM
Re: Horn rod in a 30 deluxe sedan
Check your "Pruvate Maessages" in the top right corner of this web page.
Marshall
Will N 07-14-2020 08:24 AM
You will have to loosen the steering box from the frame and remove the column support under the dash to allow the column to drop down in order to remove the horn rod.
