1934 U joint lube I want to add pack the universal joint behind the transmission in my 1934 with corn head grease. Will I have to remove the floor boards in order to add the grease?
Re: 1934 U joint lube Should be a zerk on the clamshell. It will mostly fill the cavity between the clamshell and the torquetube bell, but some will eventually make it's way to the front edge of the bell, then between the bell and the inner cone, and then into the joint area. Squirt in lots, it won't hurt anything. It will be a good test of your seal on the clamshell.
