32 intake to Stromberg carburetor adapter? Does anyone make or supply an adapter to keep the Detroit Lubricator intake on an original 32 but use a more reliable Stromberg? Not looking to change out the generator, etc. Thanks
Re: 32 intake to Stromberg carburetor adapter? |
Re: 32 intake to Stromberg carburetor adapter? One of those would create a real challenge setting up the choke and throttle controls as the Stromberg carburetor would end up mounted sideways. There could also be complications for the fuel level/float valve.
Re: 32 intake to Stromberg carburetor adapter? Yes, back in the day they made those. I have one somewhere in my stuff, and I know tomcarmen here on the Barn is running one on a very original 32 5w. Most people just put a 34 manifold on. I will let you know if I find mine, as I KNOW I will never use it. The 2 I have seen don't mount the carb sideways which would be a pain like David said.
Re: 32 intake to Stromberg carburetor adapter? Secrets on speed has an adapter that moves the orientation 90 degrees
https://www.secretsofspeed.com/carburetor-adapters.htm |
Re: 32 intake to Stromberg carburetor adapter? I believe you are going to find that the spacing of the two (2) studs on the original '32 intake are different than the spacing on the adapters. I checked with Secrets of Speed about their adapter a year or so ago and found that the adapter they offer wouldn't fit the original intake. Bummer!
I purchased an adapter made by TransDapt that would probably work. It is made to adapt several brands of carbs to several types of single barrel manifolds. I have not installed one yet as I sold the original '32 manifold. You would need the "D" shaped Stromberg base and not the "chevron" style base carb. I would shave the TransDapt adapter to the footprint of the Stromberg base. Just a thought! Good luck. https://www.jegs.com/i/Trans+Dapt/96...iABEgIJY_D_BwE Another link to a similar adapter: https://www.ebay.com/itm/Summit-Raci...ss!45177!US!-1 Stay safe! Pat |
Re: 32 intake to Stromberg carburetor adapter? Heresy! ;)
Re: 32 intake to Stromberg carburetor adapter? Why not a 1 bl from a 6cyl???????
