The Ford Barn
-   -   Seat Belt Trimming (https://www.fordbarn.com/forum/showthread.php?t=282071)
Bruce of MN 06-04-2020 04:59 AM
Seat Belt Trimming
My seat belts are too long and I want to trim them, then fold over the end and secure it with glue. Can you recommend what glue to use? Thanks!
Brian SATX 06-04-2020 06:32 AM
Re: Seat Belt Trimming
I would not depend on the glue in an accident. Take them to an upholstery shop ot get them sewed.
ModelAMike1930 06-04-2020 06:43 AM
I agree don't glue them. Years ago they used to sell aftermarket seatbelt retractors that you could put on the belts. I don't know if they are still available.
Jacksonlll 06-04-2020 08:02 AM
I know that the belt system we put in our A’s is Far from a modern car, but here is a little shoulder belt info. During a 30 MPH barrier impact, the nylon belt material that goes through the loop on the B post actually gets melted partially from the friction involved. The forces are huge and adhesive will not do the job.
1931 flamingo 06-04-2020 08:39 AM
Trimming the ends is NOT going to impact the integrity of the belt ( assume uou're doing the buckle end............), Crazy Glue, Gorilla Glue, etc. JMO
Paul in CT
BRENT in 10-uh-C 06-04-2020 08:59 AM
Can you take a picture of what you are describing? If it is the tail of the belting and the reason for the glue is to keep it from accidentally being pulled thru the buckle, then any form of Superglue will likely work. Also use a hot-knife to sear the nylon where you make the cut.
Ruth 06-04-2020 10:47 AM
I use seat belt retractors to keep my unruly seat belts under control.
https://www.julianos.com/Seat-Belt-R...p/ju010400.htm
katy 06-04-2020 11:19 AM
How do they work?
Ruth 06-04-2020 12:26 PM
Originally Posted by katy (Post 1895498)
How do they work?
Good.
CarlG 06-04-2020 12:43 PM
How do they work?
Mine work really well also. Sure does keep them from falling out on the running board and closing the door on them.
Bruce of MN 06-05-2020 05:27 AM
Thanks, Brent, that is what I had in mind. I didn't dream of trusting glue for the working part of the belt!
Werner 06-05-2020 06:15 AM
1 Attachment(s)
Bruce,
I cut off the ends and sealed the fringes with a lighter. After that, the end is covered in soft leather so that it looks nicer.
Bruce of MN 06-05-2020 03:55 PM
Thanks, Werner.
If those retractors are like the ones my Dad had in his ‘63 Impala, the center part has a windup spring and you put the belt in it and let it coil it up. Glad they work better now, not too good then.
shew01 06-13-2020 07:31 PM
Seat Belt Trimming
I just ordered a set of these based on this thread, and I’m disappointed. The ones I received from Juliano’s are made out of flimsy plastic and have a textured surface that does not slide over the belt under their own power. Essentially, I have to hand feed the seat belt to the retractor every time I take off the belt.
Also, one of the springs “jumped track” while I was installing the retractor for the first time. It was a pain to get that straightened out again.
If these retractors would have been made of smooth metal, the friction would be lower, and I could see that they might work well. The flimsy plastic that I received is hardly worth $20. Maybe my seat belts have a rougher texture than the seat belts in other cars, but they look pretty “normal” to me.
Just my 2 cents...
Ruth 06-13-2020 07:35 PM
Originally Posted by shew01 (Post 1898842)
I just ordered a set of these based on this thread, and I’m disappointed. The ones I received from Juliano’s are made out of flimsy plastic and have a textured surface that does not slide over the belt under their own power. Essentially, I have to hand feed the seat belt to the retractor every time I take off the belt. Also, one of the springs “jumped track” while I was installing the retractor for the first time.
If these would have been made of smooth metal, the friction would be lower, and I could see that they might work well. The flimsy plastic that I received is hardly worth $20. Maybe my seat belts have a rougher texture than the seat belts in other cars, but they look pretty “normal” to me.
Just my 2 cents...
I'm surprised. Mine work fine. Did you 'wind' them up tightly when you installed them. I have had them on all four belts in my Town Sedan for ~5 years now with no problems.
They also have metal ones if you prefer. https://www.julianos.com/Chrome-Seat...p/ju010401.htm I have never used the metal ones.
shew01 06-13-2020 07:54 PM
Seat Belt Trimming
Yes, I wound them according to the instructions. 7 full turns. The spring went wacky in one of them after 6 turns, but after I got that straightened out, I wound it 7 turns as well. They just don’t work well for me. Your belts probably have a different texture than mine. I don’t doubt they work fine for you.
