The Ford Barn
-   -   no spark in my Model B fixed (https://www.fordbarn.com/forum/showthread.php?t=281583)
JOHNCL 05-25-2020 04:44 PM
I tried all the usual suspects for a no spark problem at the end of the winter. Nothing worked. Then I removed the points and used a metal file to make them shiny; an emery board didn't do the job but the file did. SHAZAAM! A hot spark happened.
Gary WA 05-25-2020 05:57 PM
Re: no spark in my Model B fixed
Thanks for the update on your fix!!
CWPASADENA 05-26-2020 06:49 PM
I have run into problems with replacement Model B points. They seem to have almost no tungsten and will burn in a very short time. If your problem keeps happening, replace the points
My experience
Chris W
