The Ford Barn
-   -   Fuel pumps ? (https://www.fordbarn.com/forum/showthread.php?t=281478)
Bob NH 05-23-2020 05:42 PM
Fuel pumps ?
What years of flatheads used a fuel pump with a little petcock/shut off valve on the side ?
35fordtn 05-23-2020 05:44 PM
Fuel pumps ?
1936-42
Andy 05-23-2020 06:13 PM
Re: Fuel pumps ?
Humbly, The bigger diameter pumps were 33-35 then? I had it in my mind the small pumps were early. Thanks.
35fordtn 05-23-2020 06:20 PM
Re: Fuel pumps ?
The 32/33 pump had a petcock but the pump did not use a fuel pump stand. They are rare these days. 34/5 was a small bowl pump with a 10-32 slotted hex bolt as a drain plug. 36-42 uses a Petcock and larger diameter pump. 46/48 was the glass bowl variety.
In 36-42 there was two pumps used 68-9350 and 11a-9350.. the main difference being the height of the Inlet
